shought
Message 1 of 25
BT infinity very poor speeds
Hi all,
Please view the image below.
I was quoted I would get 62down and 19 up
However after running the line check:
Download Speed: 18.64
Upload Speed: 4.99
Ping: 38
Test 2
Download Speed
18.64 Mbps
0 Mbps 19.11 Mbps
Max Achievable Speed
^^^^ This was at 29.68 yesterday why has that gone so low?
Upload Speed
4.99 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 4.99Mbps
Additional Information:
Upstream Rate IP profile on your line is - 20 Mbps
24 REPLIES 24
john46
Message 2 of 25
Re: BT infinity very poor speeds
no downstream IP Profile shown
test 1 is not needed to be posted
download speed will constantly vary according to general internet usage
shought
Message 3 of 25
Hi there, I have just done another test view screenshot below:
Why would they said I can get 60mb down when i dont get anywhere near that? i wouldn't mind if I had 50 down and 15 up or something. But I am getting no where near the speeds I was quoted...
john46
Message 4 of 25
how long have you had infinity ?
It looks like you have been suffering line noise which has caused your line to be seen as unstable and the DLM has reduced your IP Profile in an attempt to stabilise your connection all you can do is wait for the DLM to reset your line as and when it sees the line as stable gain
shought
Message 5 of 25
I have had infinity about 5 days. Why?
john46
Message 6 of 25
just trying to get all the details so we can see any possible reasons for the problem
shought
Message 7 of 25
Okay thanks please reply when you have all details. thankyou.
john46
Message 8 of 25
the answer to your problem is in my earlier post your line has been seen as unstable and the DLM has reduced your IP Profile trying to stabilise your line all you can now do is wait until the line is seen as stable again and then the DLM will release the line and your speed will start to increase again
shought
Message 9 of 25
Right so after 10 days I should have 60 down and 19 up roughly? give or take 5 or 10mbits?
Is there anything that can be making the line unstable?
john46
Message 10 of 25
Not necessarily 10 days there is no fixed time scale for the DLM to reset you just have to wait it may start going up slowly
the most likely cause was random line noise that has caused the problem
