Message 21 of 31
Re: BT infinity wifi speed problems
Perhaps if you re read the post you will see what else was suggested!
Message 22 of 31
I suggested to check for driver update - nowhere did i suggest a new router
Message 23 of 31
I think you'll find gg the guru did...
Message 24 of 31
I appreciate the driver update advice but how would you do this update on an iPad/iPhone/Xbox etc??
Message 25 of 31
I am more than happy to hear others suggestions but the only advice that is being given is to go out and buy replacement routers which I think is unacceptable.
I think, ultimately, the only way to resolve the issue is to use a different broadband supplier as I see no other workable solution.
You assumption again is wrong as there is a suggestion that updating the driver may help so that is another alternative to a new router
The OPs problem is with laptop - no mention of anything else. You may have a similar problem but this is not your thread
Message 26 of 31
At least quote everything I said
"I am not advising you or anybody else to go out and spend money on a router or to do anything. I said you could consider buying a router or other options such as updating drivers or just moan about it."
Message 27 of 31
Ok, thanks for your expert advice. I will post in another thread...
Message 28 of 31
If this helped you please click the Star beside my name.
Ok, thanks for the advice. I have "considered" buying a new router and I do not wish to do that. I've already had to purchase a wireless booster and some tp link network adapters to get this shambles of a network just to work in an adequate manner. I'm not willing to spend anymore money especially when if I'd have just stayed with previous supplier then I would have been a lot better off.
Message 29 of 31
How do I start a new thread?
I'll see if I can get an answer elsewhere as this is not my thread, I apologise for raising my concerns in someone else's.
Message 30 of 31
select 'new message' top left of board
