Message 1 of 31
BT infinity with a Cisco router
Hello Im looking to configure a new Cisco 887va router to use Bt infinity service. So far it has not been able to connect. The router staes it natively supports VDSL2 so i assume that i configure the dialer interface unlike some other examples of people using PPPOE here.
Has anyone done this successfully and if so could they give me some pointers?
30 REPLIES 30
deathaxe
Expert
Message 2 of 31
Re: BT infinity with a Cisco router
The most important thing is that you need to set the multi-Vlan up and your login details.
Here is the setup guid for the draytek 2750n modem/router and there is the correct setting for infinity.
http://www.broadbandbuyer.co.uk/Shop/PageTextDetail.asp?SetID=4&TextID=1004
Message 3 of 31
Thank you for the reply, im intrested in seeing if someone has managed this on a cisco router and if they are willing to share the config.
I have configured the router already im hoping to use the dialer and completely replace the hub and modem provided by BT.
Has anyone tried this?
Lobotomised
Message 4 of 31
Not done this myself for a long time but I reckon this page might help you?
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080126dc0.shtml
Lobotomised
Message 5 of 31
<ignore>
Message 6 of 31
Thanks for your replies to go a bit further
Im setting up a CISCO887VA-SEC-K9 router to use BT infinity. Im looking to use PPOE with a passthrough to the BT Modem.
I have all the interfaces up but when i test the connection I get a line down message.
Below is my config I wanted to enable all the ports to use the VLAN but despite doing no shut the router is not pingable on all but the last port.
Any help is gratefully recieved
controller VDSL 0
bba-group pppoe global
interface Ethernet0
no ip address
interface Ethernet0.35
encapsulation dot1Q 35
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
shutdown
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
switchport access vlan 100
interface Vlan1
no ip address
interface Vlan100
ip address 192.168.100.1 255.255.255.0
ip flow ingress
ip nat inside
no ip virtual-reassembly in
ip route-cache policy
ip tcp adjust-mss 1452
interface Dialer1
description VDSL
mtu 1492
ip address negotiated
no ip redirects
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username <username> password 0 <password>
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
logging esm config
access-list 1 permit any
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
perksta
Message 7 of 31
Have you seen the config at the bottom of this page
http://www.dslreports.com/forum/r26643011-Config-Cisco-1921-and-HWIC-1VDSL
Supplanter
Message 8 of 31
Hi Newbie,
Your config looks good apart from et0.35 where you are tagging in the wrong vlan. It should be 101 and you can use the built in vdsl modem with no external Openreach one.
interface Ethernet0
 description Connection to BT Infinity (VDSL 0)
 no ip address
interface Ethernet0.101
 description 802.1Q Tagging for PPPoE (VDSL 0)
 encapsulation dot1Q 101
 pppoe enable group global
interface Dialer1
 description I put my tel number here so I know what line is what on multiple interfaces
 mtu 1492
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nbar protocol-discovery
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer-group 1
 keepalive 30
 ppp authentication chap callin
 ppp chap hostname youremail@btinternet.com
 ppp chap password yourpassword
 no cdp enable
You don't need the tcp adjusment on vlan100 just put it on di1. Not sure if you are connecting that to the openreach modem or your internal network. Looking at the config could be either. You don't want to adjust that on your internal network though. Could posibly affect internal speeds.
If it is connect to the openreach modem you no longer need it with the above config and can connect the router right up to the line. This way you can take VLAN100 and Fa3 off.
I can't see all the config but this works. Make sure the VDSL is set to auto mode and you may need to apply any relevant ACL to di1 if required.
conf t
controllers vdsl 0
operating mode auto
end
I am flying:
                      DS Channel1      DS Channel0       US Channel1         US Channel0
Speed (kbps):   0                      79987                0                        19999
Noise Margin: 14.7 dB 23.3 dB
Attainable Rate: 11176 kbits/s 38891 kbits/s
Actual Power: 12.8 dBm  6.8 dBm
Hope that helps. I can mail you a complete config if need be.
Supplanter
Message 9 of 31
Just seen we are all called Newbie and you username is "HelpWithCiscoConfig" sorry 🙂 lol
gg30340
Message 10 of 31
Hi Supplanter
Good post but hopefully the OP has managed to get things sorted out before now. The post is over 2 years old but I'm sure it will be helpful to anybody who has that router. Smiley Wink
