jackneedham
Newbie
Message 1 of 2
BT infinity
I'm getting BT infinity installed but theres a snag, my master socket is under laminate flooring. What will happen? Will the engineer have to create a new master socket or something? How much will this cost?
1 REPLY 1
blooty
Message 2 of 2
Re: BT infinity
There is a possibility an extension socket can be converted into your main socket, if you've got one... however it's possible part of the laminate might have to come up :s
Someone that's had their extension socket converted should be able to shed a bit more light...
What's your socket set up? quite strange that you've been able to install a laminate floor over it..
If i've given you a helpful answer please rate me by clicking the rating star to the left 😄
BT Total Broadband Option 4 - London - Pimlico Exchange
