Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
A quick one I think- my BT main socket is under the stairs and my router lives there. my phone is in the kitchen and there is a socket there with a cat6 cable connecting to socket to the space under the stairs. I had wired the cat6 cable into the extension point behind the main BT socket and had plugged my router straight into the front of the main socket. just realised that my internet would go down when using the landline- presume this is because there is no micro filter? Believe I'm on fibre if that makes any difference.
How wouldyou go about wiring this to avoid that happening?
Many thanks
T
Master socket like this ? If so extension should be connected to terminals 2&5 on back of bottom faceplate and no filter required. Router connected direct to top socket on master
Then you need a filter.
Can you be more specific as to exactly what it is you are doing, it is not entirely clear from your original post. Do you intend to use the original location of the master socket for your router and phone or are you intending to effectively move the master socket to a new location and use that for telephony and your router? You shouldn't have 2 master sockets in circuit. Not sure what you mean by connecting cat5 into a fllter. A filter just plugs into a phone socket and provides an unfiltered RJ11 socket for the router and a filtered socket for the phone.
Just get 2 filters, one for each socket.
The master socket should have a removable front faceplate which plugs into the test socket. The cable to the extension should be wired to terminals 2&5 of the removable faceplate, not to the rear of the backplate of the master.
When you say the cat5 is connected straight into back of main socket do you mean to terminals A&B where the main incoming wires are connected? If so then just instead of connecting to back connect to terminals 2&5 on front plate then use filters on both sockets
@tobydean131 wrote:
The router is connected straight into the front of the socket - no filter.
How can that be? You said the socket has only one port at the front- a flat telephone jack. A router plug (RJ11) does not fit a phone socket, without using a dangly filter to receive the router's RJ11 plug.
Whatever else you need to have a dangly filter on every used phone socket or replace the master faceplate by a filtered faceplate with 1 socket for phone & the other for DSL. And move this "Cat 5 cable" to the back of the faceplate, not the back of the main BT socket.
