Message 11 of 12
Re: BT says 5 Mb/s, speed tests 0.32 Mbs
IP Profile has just jumped back up to 4Mbs.  Not doubt that this will get sacked when BT engineering comes to check the line but at least I now understand the impact of reseting the HomeHub too often.
Thanks for your advice.
Message 12 of 12
hopefully you may be ok it may be worth turning the hub off before the visit then turning it on after that may reduce the risk of the connection getting disturbed it has worked for me in the past
