Message 1 of 9
BT says everything is fine, but can't have conference calls
I have recently move from Virgin Media to BT, and I am thinking I am made a huge mistake. Need some advice before I cancel BT as it is not fit for purpose.
There are 3 internet users in my house, working or studying from home, an in many periods throughout the day we will all be on conference calls with our cameras on. We have a smart hub and a complete home wifi, signal is strong around the house.
My download speed is typically 50Mbps connected to the disc, but on conference calls it all suddenly stops working, my camera freezes, other people can't hear me and the internet just stops working although WiFi signal is still strong. After rebooting the hub things get back to normal, but have been doing this 2/3 times a day and everyone needs to stop their calls so we can reboot the hub.
The reason to move from Virgin Media was that their service was not reliable and would go down for days,  but BT doesn't seem to be much better...
BT line tests show all is good, with some "drop outs" (whatever that is) but person on the phone said there was nothing wrong.
8 REPLIES 8
Message 2 of 9
Re: BT says everything is fine, but can't have conference calls
I am far from an expert.... But do you have the smart wifi channel switching on or are you on a fixed channel that never changes??
I turned mine off after a few days as it constantly changed the wifi channel and would drop the connection whilst doing so.
I also have the wifi discs (2 of them) and I had to turn one of them off as my devices kept swapping between them all the time and it was killing my wifi speed.
Anonymous
Not applicable
Message 3 of 9
If you haven't already done so, turn off Smart setup and reboot your hub (open a browser, navigate to 192.168.1.254 and (if SH2) Smart Setup is in the bottom row of tiles)
Message 4 of 9
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
you need to stop resetting the router otherwise your line will be seen as unstable and the DLM will take action to try and stabilise your line resulting in a drop in connection speed and increase in noise margin
Someone may then be able to offer help/assistance/suggestions to your problem
Message 5 of 9
I need to investigate this, haven't done any of that.
Thank you.
Message 6 of 9
This is the Technical log:
Product code:Smart Hub 2
Serial number:+091298+2021008017
Firmware version:v0.17.01.12312-BT
Firmware updated:Sat Aug 8 00:39:54 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:2 days,23 Hours16 Mins51 Secs
Data rate:9.999 Mbps / 55 Mbps
Maximum data rate:23.728 Mbps / 64.542 Mbps
Noise margin:22.1 / 8.3
Line attenuation:9.2 / 13.5
Signal attenuation:9.1 / 16.7
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:5.7 GB Uploaded / 41.2 GB Downloaded
Broadband username: [email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:XXXXXXX
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:XXXXXX
5 GHz wireless channel:Smart (Channel44)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:18:82:8C:32:2B:6F
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 7 of 9
from your stats you are on Fibre 1 with max connection 55/10mb and line has been stable for virtually 3 days - looks good
Message 8 of 9
This is the result of the Broadband Availability Checker:
Message 9 of 9
Thank you.
Is there anything I should capture when I do have the issue?
I have just noticed there is also an event log on the SH, would I see any signs of problems in there?
