SkyblueAndy
Message 1 of 2
BT smart hub BT Access control Wireless devices, smart hub thinks its Friday when its a Saturday
I have set up access control for several wireless devices on my smart hub that my nephew uses and have set the days and times for access without any problems until today.
Today my nephew tells me he cannot get access via his laptop, check the settings everything's fine, he should have access.
Today is a Saturday, my smart hub is believing it to be a Friday still. I change Friday's wireless access times and voila the laptop is connected.
I have tried other wireless devices and the same thing happens.
Do I need to do a factory reset? or is there another way to manuallly correct the day/date issue?
1 REPLY 1
RobbieMac
Moderator
Moderator
Message 2 of 2
Re: BT smart hub BT Access control Wireless devices, smart hub thinks its Friday when its a Saturday
Hi @SkyblueAndy
Thanks for posting.
Strange issue!  Sorry you've had this problem.  I'd suggest a factory reset as first port of call.  Let me know how you get on with this.
Cheers,
Robbie
