Message 21 of 34
Re: BT smart hub alternative
Hi
Just found this thread. Having major issues with the home hub going orange at random.
I have ordered the tp link modem router mentioned in the thread. I use the Orbi mesh net work around the house so have the WiFi turned off on the home hub. How do I set the tp link up to do the same job of the home hub? Ie no WiFi and just pass the internet access to the orbi to send around the house?
Josh
Message 22 of 34
If the hub is going orange, I doubt it is the hub that is faulty, more likely a line fault which will still be apparent whatever router you use
Message 23 of 34
You can simply turn the wifi off on the TP Link via the web interface. Do it on both networks.
I also believe there is a switch on the back which does the same thing.
It also worth checking your phone line to see if there is any noise on it, in case you also have a line fault as @licquorice  has said.
Message 24 of 34
thanks,  will get the line tested as well
Message 25 of 34
You will have to do that yourself, using a phone, as the BT line test cannot detect a noisy line.
Dial 17070 and select option 2, there should be no noise between the announcements.
Message 26 of 34
thanks.  done the test and completely quiet.
Message 27 of 34
Then you will have to see how the VR400 behaves, as the home hub 6 does seem to be very fussy about line conditions.
Message 28 of 34
thanks All,
The modem is due to be delivered today.  Do I just switch it on and plug in the cable from the wall that goes to the homehub now or is there something extra to do?   I use orbi for the wifi so I know i need to connect the orbi to the tplink.
thanks
Josh
Message 29 of 34
Hi
just providing a quick update.  The tp link modem is installed and connected to my Orbi.   One week later (almost), and zero drop outs of the network so it looks like the home hub was faulty.
Thanks again for for the help.
Josh
Message 30 of 34
Excellent Smiley Happy
