nirvana316
Message 21 of 23
Re: BT speed far less than promised Atten: NeilO
This is what I have in my attic.
So the black cable comes in from an outside pole. It reaches this junction box then splits into two extension sockets. One is unused and the other is in my bedroom.
(1) could this setup be the reason I am getting lower speed than I should (10 to 20 mbps from an infinity 2 connection and phone line rated at 40 mbps)
(2) If I asked for a BT engineer to come would he fix this? would i get charged
Craig
Jayebmx
Message 22 of 23
Hi Craig,
If you can get a pack of jelly crimps, they are normally quite cheap and can be found online. What the engineer will do is jelly crimp the external cable to the internal wiring to the socket, so if you can identify the correct wire, (hopefully by colour, as one looks older than the other) i'd personally go with the white cable as it looks like a 3 pair or 4 pair cable, and then follow the pattern they are connected to and jelly crimp the correct cables together.
Im pretty sure openreach will charge you for that as it looks like a problem with the internal wiring and assuming not their equipment.
-Jaye.
licquorice
Message 23 of 23
Just simply disconnect the wires that go to the unused extension as stated previously, the 2 cables are different colour sheathing so should be obvious which one goes where.
