Expert
Message 1 of 15
BT speed tester
Okay, so concensus is that the BT speed tester is not working as it gives highly erratic results if any at all.
SO, just why do the MODS request you carry out a speed check using this tool?
Apart from the fact I have a failing Hub3 type'A', what is being gained by testing through a medium that is not capable of working correctly in the first place?
Oh it gives ME a headache....:)
14 REPLIES 14
Message 2 of 15
Re: BT speed tester
It still gives an accurate representation of your profile which indicates the maximum download and upload you can get and therefore what you should realistically get. I agree the actuall speed results are very erratic at the moment. I think most people here now request a speed test result from Speedtest.net. That said apparently the BT speed test is going to be updated and fixed in about a week.
Message 3 of 15
Re: BT speed tester
Hi
    I have been running the speed tester over the last few days and it seems to be working ok. ( for me at least)
 here is one I just ran a few minutes ago.
 Not to bad for a bank holiday result
Message 4 of 15
Re: BT speed tester
It's been quite erratic for me as well as it seems several others who have posted in these forums.
Message 5 of 15
Re: BT speed tester
Very erratic for me also but I think IP profile is accurate.
Message 6 of 15
Re: BT speed tester
It is very erratic for me. If it takes a long time between completing the download test and starting the upload test, it seems to mess up the download result. It works maybe 1 in 10 times.
Also, the profile started saying 38.71 now instead of 38.72....weird! It would be near impossible to just have the perfect connect speed fractionally under the max that would result in a genuine profile of 38.71!!
Expert
Message 7 of 15
Re: BT speed tester
Boo Hoo still don't love me:-
iechyd da
Message 8 of 15
Re: BT speed tester
Hi Paul,
At least you know it's just the speedtester that is suffering from something! (lack of investment?) - when I saw those figures it was a duff gigabit port on my 3A.
Michael.
Expert
Message 9 of 15
Re: BT speed tester
Well, BT been here and gone again now. New Hub3 and guess what? It is Version 1A again. New modem version 2B again.
Speeds seem to have come up again so let's see what happens. Appears all he had on the van. Still waiting for the new modems.
Message 10 of 15
Re: BT speed tester
Try running your tests at www.speedtest.bbmax.co.uk
I've found it to be much more consistent.
