on 21-01-2017 17h07
Solved! Go to Solution.
on 22-01-2017 15h10
Hi @ianpeterson83,
You can log in to the BT Sport app using your BT ID and password. Your BT ID is usually your email address - but you can go here to check. If you've also forgotten your password, you can reset it here.
on 22-01-2017 20h04
