daydreamer
Message 1 of 7
BT sports,help please
hi ive tried to get the online player and all i keep getting told is this...
There's been a technical error – but you can still place your order online.
To order a Broadband and Calls package with optional TV, click here
To add BT Vision to your existing BT broadband package, click here
To order a new phone line, click here
To switch your calls back to BT Click here
Ref# CON-0113
any ideas? thank you
6 REPLIES 6
MalcsHelp
Message 2 of 7
Re: BT sports,help please
Go to (My Account) then to update details and make sure your current telephone number is listed. If not, insert your number and press update. This solved my problems with BT Sports
daydreamer
Message 3 of 7
do you mean on my bt? if so it is showing
daydreamer
Message 4 of 7
its working now,thank you
TRUDDERZ
Message 5 of 7
daydreamer, how did you get it to work?
When I try I get the same error message you posted.
daydreamer
Message 6 of 7
hi TRUDDERZ i just went back today to try again and it worked
TRUDDERZ
Message 7 of 7
ahhhaa, brilliant! Smiley Very Happy  pot luck...
I'll take your advice and come back and try again! 🙂
Thanks, daydreamer Smiley Happy
