Message 11 of 15
BT taking incorrect amount from my account. THIS MESSAGE HAS NOT BEEN SOLVED!
can't you just do a av scan/reformat?
I honestly can't see BT doing anything
If I helped, then consider clicking the star to the left
Message 12 of 15
Where you the guy who got banned? BT would NOT put a virus on your laptop and like the poster above said why not do a av scan?
Message 13 of 15
Also, 'Ripped-off', You should really keep your topics in one thread. Its no good going off on one when nobody actually knows what you are talking about.
Message 14 of 15
Read the message stealing from my account then you will know what im on about.
Message 15 of 15
You are missing the point.
Nobody is going to help you if they don't know what you are talking about. Nor will they care that much to go sifting through 100's of other more coherant posts to find your origional post that explains the above.
If you are updating on a matter you have raised previously on your older thread then you should update that thread to avoid confusion.
