Message 1 of 2
BT virus protection freezes Chrome
Hi
I'm a Windows 8.1 user and all of a sudden cannot get onto Chrome. I tried to uninstall the virus protection and everything works fine. But after reinstalling it again, everything freezes.
Please advice any solution to this problem or could you let me know if there will be an update coming out to fix this issue?
Many thanks,
M
1 REPLY 1
Message 2 of 2
Re: BT virus protection freezes Chrome
I personally don't and wouldn't use BT Virus Protect/McAfee but if it is blocking Chrome you should go into McAfee's firewall and check if it set to allow full access to Chrome.
