kkkbbb7788
Message 1 of 3
BT with Freeview piped to rest of the house
Hi, hoping someone can help, we've recently moved from sky (main tv) with Freeview piped round 4 other rooms from the Digital area outside, since moving to BT, I've lost signal on all of the 4 tvs, can someone please help, I've spent hours trying to find the solution to no avail. Main aerial going into BT box, I've activated the RF loop and this made no difference.
Thank you in advance.
Kim
2 REPLIES 2
brianhes
Message 2 of 3
Re: BT with Freeview piped to rest of the house
The Youview box seems to cut the RF loop when in high eco standby. There is no RF output from the Youview box, but Freeview receivers should be able to use the loop through if high eco standby is not used.
Devon_Dave
Distinguished Guru
Message 3 of 3
Have you done a re - scan for channels on the TVs?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
