matty2
Message 1 of 7
BT working wirelessly but not via wired connection
Hello,
I own a BT home hub 3. I have numerous devices connected via wireless connection and all working fine however my PC which is connected via etherenet is not working.
6 REPLIES 6
imjolly
Message 2 of 7
Re: BT working wirelessly but not via wired connection
Phone customer services and ask for a replacement to the hh2. It is old now and has known faults
http://forumhelp.dyndns.info/hardware/hh2/hh2_issues.html
matty2
Message 3 of 7
my friends home hub 3 works though and it works on his home wired network therefore it is not the router. I may also add it is not the wireless that is the problem as per previous post but it is the wired connection that is causing the problem.
imjolly
Message 4 of 7
Make sure your driver for network card is it to date from manufacturers website nod don't rely on windows update
matty2
Message 5 of 7
thanks for your reply but I have installed the most recent driver and it is also not working on other PCs/laptops therefore it is not the computer
imjolly
Message 6 of 7
If you cannot get Ethernet to work on your hh3 with pc but PCs works when using another hub connecting Ethernet then that suggests a hub fault
Maybe would help if you said all you have tried
gg30340
Message 7 of 7
Have you tried a different Ethernet cable?
