Hello,
I own a BT home hub 3. I have numerous devices connected via wireless connection and all working fine however my PC which is connected via etherenet is not working.
my friends home hub 3 works though and it works on his home wired network therefore it is not the router. I may also add it is not the wireless that is the problem as per previous post but it is the wired connection that is causing the problem.
thanks for your reply but I have installed the most recent driver and it is also not working on other PCs/laptops therefore it is not the computer
Have you tried a different Ethernet cable?
