Message 1 of 4
BT youview box auto log in to NowTV
I used to have BT entertainment package which included NOW TV entertainment, but I no longer use it, so my BT account has no NOW packs or passes associated with it at all. - however the account still exists.
When I open the NowTV app on my BT YouView Box, it automatically logs me in to my BT account, there seems to be no way of avoiding this.
I currently have a Sky Sports pass in a different account, directly with NowTV and no link to BT at all.
In order to watch Sky Sports, I have to launch NowTV, scroll down, sign out, then sign in again with the other account.
This happens every time I launch the app, not just after stand-by or switching off.
I have tried a number of times with BT to disassociate the account, they don't seem to be able to do it.
I have factory reset the box - no change. I am convinced it is an account setting, not a hardware setting.
The latest advice from BT is to remove the NowTV account associated with BT, but I can;' seem to do that.
I contacted NowTV, but apparently my request goes to a 'special department' and will take 1 month before the account is deleted. - Even then, I'm not sure if this will solve things.
Anyone else had this problem, or have any advice ?
3 REPLIES 3
Message 2 of 4
Re: BT youview box auto log in to NowTV
@crush123
How are you doing the "Factory Reset" - from the Settings menu or by interrupting the boot up of the box?
I have a regular problem with my box's analogue AV output that is fed to another room - every so often it stops outputting the audio out of the phono sockets. I have found that the only way to cure this is to do a Factory Reset during the boot up - doing it via the Settings menu does not cure my issue. Unfortunately, this also has the effect of clearing my NowTV app login details, (I too have a Sky Sports pass associated with a different account). When setting up NowTV again it is treated as a new device - taking up a new slot as one of the 6 devices allowed, (for up to a month).
So, a Factory Reset from the boot menu might clear your login details to achieve what you want?
Message 3 of 4
Thanks for the feedback.
I was doing the reset from the menu - done it twice.
the reason I am convinced that the problem is account related is that I have 2 youview boxes, one of which I hardly ever use for now tv, and that has the same issue.
until I had the entertainment pack with BT, it wasn’t an issue.
Message 4 of 4
Will try your advice tho, with the other box- but will wait a week or so, as I too have had to change the device a few times when I reset the box
