Message 1 of 3
BT4600 phone. Scrolling numbers
Good afternoon
On a recommendation I bought a set of BT4600 phones.
Unfortunately, they seems to have a major problem - for me, in that the display 'scrolls' numbers that you have stored in the phone book or have recently called.
I find this difficult to deal with. Because the number moves before you have seen what it is.
Is there any way to stop the number scrolling? If not is there a better phone that does call blocking but which does not scroll?
Any help gratefully received.
2 REPLIES 2
Message 2 of 3
Re: BT4600 phone. Scrolling numbers
Hi again everyone
I have looked through the manual and can't see a solution - though it may just be me not looking properly.
That being said. Does anyone have any suggestions for a good call blocking phone. We need one that rings loudly and has good quality voice , and call blocks. And which does NOT have scrolling numbers. We want to be able to read the number on the display.
Thanks for any help in choosing.
Message 3 of 3
Goodle is your friend
