Message 1 of 2
BT71 Mini Hub.
I have just taken delivery of a BT71 Mini Hub for mobile broadband.
The default IP address is 192.168.1.1, but I need to change this so I can VPN into our office server which is on that IP range.
I've looked thru the manuals, logged onto the device. I can not find any options to change this.
As this is a business device, there must be a way of changing the default IP address.
Can someone please advise.
Thank you.
1 REPLY 1
Message 2 of 2
Re: BT71 Mini Hub.
as it is for business you need to post here as this is residential forum
https://business.forums.bt.com/
