Message 1 of 2
BT8500 - extending the number of times the phone rings
Have had this phone for just about 12 months. Its alround performance is very good, though we get a few problems when taking calls on a mobile because our local area connectivity is rather poor.  However, I have a problem with extending the number of times the phone rings - usually 3-4 - before the caller is cut off.  I've trawled through the set-up and user guide numerous times but have been unable to solve this issue.  We have two handsets in use, with the option, of a third, but you can bet that one or other is out of reach when the phone rings three times before cutting out!  Grateful for assistance with this.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT8500 - extending the number of times the phone rings
Hi @geoffpowers and thanks for posting.
Can you take a look at Extend number of rings before answerphone kicks in and let me know if that helps. I know it's an old thread but it's worth checking.
Cheers
David
