twedledee
Message 11 of 22
Re: BTHH4 speed is dreadful. Frequent restarts needed to get good speed for about 30 minutes!
Why are my posts being deleted? I've reposted my log 2x times. They appear, and when I check back, they're gone :S
john46
Message 12 of 22
there is no reason that that should be happening
imjolly
Message 13 of 22
are you trying to post the full log or just the 2 lines with the conenction and noise margin information?
twedledee
Message 14 of 22
Trying the full log, maybe some sort of spam filter is auto-deleting? 😛 Here's the speed test / extra diagnostics: Download 0.10 Upload 0.24 Ping Latency MS: 101.75 DIAGNOSTIC TEST on Phone Number Download speed achieved during the test was - 0.1 Mbps For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps. IP Profile for your line is - 12.92 Mbps Upload speed achieved during the test was - 0.24Mbps Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps
john46
Message 15 of 22
are you using a wired or wireless connection when doing the speedtest
twedledee
Message 16 of 22
Wired connection 🙂
imjolly
Message 17 of 22
these figures are really low
have you tried a factory reset of the hub using the recessed button on the back and holding till lights flash?
is there any exchange problems http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
twedledee
Message 18 of 22
A reduced service thing on my exchange today apparently, although this has been ongoing for 2-3 days like this.
Will the reset button reset my SSID/password and network name? Or will the network name always be the default (as on the sticker under the hub?)
john46
Message 19 of 22
all default settings remain your hub login password will also revert to the default
john46
Message 20 of 22
which exchange arer you on ?
