twedledee
Message 1 of 22
BTHH4 speed is dreadful. Frequent restarts needed to get good speed for about 30 minutes!
Hi there,
For the past few days my BTHH4 has been on the verge of unsuable. I have to restart the hub multiple times a day for my business (and pleasure), a restart will grant me with a small window of 'half decent' speed, until bottoming out to near-useless speed. When google fails to load you know your ISP has a problem.
I'm based in the Swale area (Kent) and would love to hear if anyone in the area has similar issues. No differences on my end, no cable knocks or anything, just an unexplained lack of service. It's been fine since we had the internet/phone installed at the begninning of April and not too happy we're having these issues already.
Can anyone help?
Many thanks 🙂
21 REPLIES 21
imjolly
Message 2 of 22
Re: BTHH4 speed is dreadful. Frequent restarts needed to get good speed for about 30 minutes!
as you appear to be a business user you need to post here https://business.forums.bt.com/  as this forum is for residential customers
twedledee
Message 3 of 22
No i'm residential, I Just work from home, we use the internet for home use too (apple tv, etc, all been affected)
Tags (1)
imjolly
Message 4 of 22
ok just when you said you have to restart many times during the day for your business - so thought it must be a business conenction not residential
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
twedledee
Message 5 of 22
Log (I was using teamviewer with a partner so ignore any strangeness regarding remote access)
LOG
11:40:08, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 135.0.61.200:33064-​>31.51.59.156:64435 on ppp0)
11:40:02, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [76.23.249.251:59834] ppp0 NAPT)
11:39:55, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 128.73.224.154:3294-​>31.51.59.156:64421 on ppp0)
11:39:52, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [87.74.72.150:23601] ppp0 NAPT)
11:39:51, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [87.74.72.150:23599] CLOSED/SYN_SENT ppp0 NAPT)
11:39:38, 25 Jun. BLOCKED 1 more packets (because of Packet invalid in connection)
11:39:37, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 213.120.177.177:80-​>31.51.59.156:64408 on ppp0)
11:39:05, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 108.169.239.238:22907-​>31.51.59.156:64385 on ppp0)
11:39:01, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [157.55.130.142:40001] ppp0 NAPT)
11:38:59, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 108.169.239.238:22907-​>31.51.59.156:64385 on ppp0)
11:38:40, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [75.186.86.205:40655] ppp0 NAPT)
11:38:25, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [76.23.249.251:4593] ppp0 NAPT)
11:38:14, 25 Jun. ( 6562.210000) WPS registration completed successfully for 00:00:00:00:00:00
11:38:02, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [76.23.249.251:59834] ppp0 NAPT)
11:37:44, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 213.120.177.177:80-​>31.51.59.156:64358 on ppp0)
11:37:12, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:39393-​>31.51.59.156:80 on ppp0)
11:37:01, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [157.55.130.142:40001] ppp0 NAPT)
11:37:00, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:39343-​>31.51.59.156:80 on ppp0)
11:36:55, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [185.57.72.56:52743] CLOSED/TIME_WAIT ppp0 NAPT)
11:36:52, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:39343-​>31.51.59.156:80 on ppp0)
11:36:46, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [185.57.72.56:52743] CLOSED/SYN_SENT ppp0 NAPT)
11:36:42, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [197.221.242.164:41213] CLOSED/TIME_WAIT ppp0 NAPT)
11:36:40, 25 Jun. BLOCKED 1 more packets (because of Remote administration)
11:36:40, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:41259-​>31.51.59.156:443 on ppp0)
11:36:34, 25 Jun. BLOCKED 1 more packets (because of Remote administration)
11:36:33, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:41259-​>31.51.59.156:443 on ppp0)
11:36:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [197.221.242.164:41167] LAST_ACK/FIN_WAIT_2 ppp0 NAPT)
11:36:31, 25 Jun. BLOCKED 1 more packets (because of Remote administration)
11:36:30, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:41259-​>31.51.59.156:443 on ppp0)
11:36:29, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [197.221.242.164:41213] CLOSED/SYN_SENT ppp0 NAPT)
11:36:28, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [197.221.242.164:41167] CLOSED/SYN_SENT ppp0 NAPT)
11:36:12, 25 Jun. ( 6439.550000) WPS button pressed
11:36:04, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [41.43.69.162:17408] ppp0 NAPT)
11:36:03, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [185.23.124.116:10443] ppp0 NAPT)
11:36:02, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [41.43.69.162:17440] CLOSED/SYN_SENT ppp0 NAPT)
11:35:56, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [185.23.124.116:10460] CLOSED/SYN_SENT ppp0 NAPT)
11:35:53, 25 Jun. ( 6420.540000) Admin login successful by 192.168.1.68 on HTTP
11:35:50, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 66.188.84.191:15618-​>31.51.59.156:64286 on ppp0)
11:35:46, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [31.51.40.178:14272] ppp0 NAPT)
11:35:45, 25 Jun. BLOCKED 1 more packets (because of Packet invalid in connection)
11:35:38, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 24.65.107.216:28372-​>31.51.59.156:64281 on ppp0)
11:35:26, 25 Jun. ( 6393.650000) WPS button pressed
11:35:26, 25 Jun. ( 6393.650000) WPS activated
11:35:24, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [89.217.1.68:46730] ppp0 NAPT)
11:35:18, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [78.222.66.1:5497] ppp0 NAPT)
11:35:14, 25 Jun. ( 6382.240000) Admin login FAILED by 192.168.1.68 on HTTP
11:34:46, 25 Jun. ( 6354.010000) New GUI session from IP 192.168.1.68
11:34:00, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [31.51.40.178:49497] TIME_WAIT/CLOSED ppp0 NAPT)
11:33:33, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 96.21.145.5:64938-​>31.51.59.156:64177 on ppp0)
11:33:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [78.222.66.1:51046] TIME_WAIT/CLOSED ppp0 NAPT)
11:33:28, 25 Jun. BLOCKED 1 more packets (because of Packet invalid in connection)
11:33:27, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 96.21.145.5:64938-​>31.51.59.156:64177 on ppp0)
11:33:24, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [89.217.1.68:46730] ppp0 NAPT)
11:33:18, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [182.185.225.107:25180] ppp0 NAPT)
11:33:11, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 37.252.162.157:80-​>31.51.59.156:64144 on ppp0)
11:33:09, 25 Jun. BLOCKED 1 more packets (because of Packet invalid in connection)
11:33:08, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 37.252.162.22:443-​>31.51.59.156:64145 on ppp0)
11:33:07, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.197.59:443-​>31.51.59.156:64143 on ppp0)
11:32:59, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [31.51.40.178:14272] ppp0 NAPT)
11:32:58, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [31.51.40.178:49497] CLOSED/SYN_SENT ppp0 NAPT)
11:32:31, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [78.222.66.1:5497] ppp0 NAPT)
11:32:30, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [78.222.66.1:51049] LAST_ACK/FIN_WAIT_2 ppp0 NAPT)
11:32:30, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [78.222.66.1:51049] CLOSED/SYN_SENT ppp0 NAPT)
11:32:28, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [78.222.66.1:51046] CLOSED/SYN_SENT ppp0 NAPT)
11:32:25, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [151.227.204.128:52515] TIME_WAIT/CLOSED ppp0 NAPT)
11:31:46, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 178.74.60.55:63409-​>31.51.59.156:64093 on ppp0)
11:31:34, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [77.101.113.161:57726] CLOSED/SYN_SENT ppp0 NAPT)
11:31:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [77.101.113.161:56942] FIN_WAIT_1/ESTABLISHED ppp0 NAPT)
11:31:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [77.101.113.161:56942] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:32, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [77.101.113.161:56942] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:24, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [151.227.204.128:52520] LAST_ACK/FIN_WAIT_2 ppp0 NAPT)
11:31:23, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [151.227.204.128:52520] CLOSED/SYN_SENT ppp0 NAPT)
11:31:22, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [151.227.204.128:52515] CLOSED/SYN_SENT ppp0 NAPT)
11:31:17, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [182.185.225.107:25180] ppp0 NAPT)
11:31:16, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:22003] FIN_WAIT_1/ESTABLISHED ppp0 NAPT)
11:31:15, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:22003] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:15, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:22003] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:15, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:22003] CLOSED/CLOSED ppp0 Route)
11:31:00, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [80.103.184.143:55081] ppp0 NAPT)
11:30:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:3542] SYN_RECV/SYN_SENT ppp0 NAPT)
11:30:26, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [75.186.86.205:40655] ppp0 NAPT)
11:30:13, 25 Jun. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.68:59814-​>195.135.250.57:3542 on ppp0)
11:30:11, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [76.23.249.251:4593] ppp0 NAPT)
11:30:11, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:3542] CLOSED/SYN_SENT ppp0 NAPT)
11:30:09, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [195.135.250.57:22003] CLOSED/SYN_SENT ppp0 NAPT)
11:29:28, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 23.62.98.194:80-​>31.51.59.156:50312 on ppp0)
11:29:26, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.65:64033 <-​-​>31.51.59.156:64033 [212.33.102.60:20535] ppp0 NAPT)
11:29:16, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [41.109.250.12:11212] ppp0 NAPT)
11:28:59, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [80.103.184.143:55081] ppp0 NAPT)
11:28:50, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.194.246:443-​>31.51.59.156:64042 on ppp0)
11:28:33, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [157.55.130.142:40001] ppp0 NAPT)
11:28:25, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [75.186.86.205:40655] ppp0 NAPT)
11:28:10, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [76.23.249.251:4593] ppp0 NAPT)
11:28:09, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [103.241.47.102:39693] ppp0 NAPT)
11:27:45, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [76.23.249.251:59834] ppp0 NAPT)
11:27:28, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-​-​>31.51.59.156:59814 [82.39.129.210:56176] ppp0 NAPT)
END LOG
Quiet line test - can't hear anything (just tried now)
The BT speed test is taking ages to even load up, a good gauge of my speed 😄
RESULTS OF SPEED TEST
Download 0.10
Upload 0.24
Ping Latency MS: 101.75
Nice! Please advise.
twedledee
Message 6 of 22
arghh I edited my post with further diagnostic results in and it's now vanished (Awaiting approval? Please tell me it's not deleted itself)
twedledee
Message 7 of 22
here it is again 🙂
LOG
11:40:08, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 135.0.61.200:33064->31.51.59.156:64435 on ppp0)
11:40:02, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [76.23.249.251:59834] ppp0 NAPT)
11:39:55, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 128.73.224.154:3294->31.51.59.156:64421 on ppp0)
11:39:52, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [87.74.72.150:23601] ppp0 NAPT)
11:39:51, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [87.74.72.150:23599] CLOSED/SYN_SENT ppp0 NAPT)
11:39:37, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 213.120.177.177:80->31.51.59.156:64408 on ppp0)
11:39:05, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 108.169.239.238:22907->31.51.59.156:64385 on ppp0)
11:39:01, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [157.55.130.142:40001] ppp0 NAPT)
11:38:59, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 108.169.239.238:22907->31.51.59.156:64385 on ppp0)
11:38:40, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [75.186.86.205:40655] ppp0 NAPT)
11:38:25, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [76.23.249.251:4593] ppp0 NAPT)
11:38:02, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [76.23.249.251:59834] ppp0 NAPT)
11:37:44, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 213.120.177.177:80->31.51.59.156:64358 on ppp0)
11:37:12, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:39393->31.51.59.156:80 on ppp0)
11:37:01, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [157.55.130.142:40001] ppp0 NAPT)
11:37:00, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:39343->31.51.59.156:80 on ppp0)
11:36:55, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [185.57.72.56:52743] CLOSED/TIME_WAIT ppp0 NAPT)
11:36:52, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:39343->31.51.59.156:80 on ppp0)
11:36:46, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [185.57.72.56:52743] CLOSED/SYN_SENT ppp0 NAPT)
11:36:42, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [197.221.242.164:41213] CLOSED/TIME_WAIT ppp0 NAPT)
11:36:40, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:41259->31.51.59.156:443 on ppp0)
11:36:33, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:41259->31.51.59.156:443 on ppp0)
11:36:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [197.221.242.164:41167] LAST_ACK/FIN_WAIT_2 ppp0 NAPT)
11:36:30, 25 Jun. IN: BLOCK [16] Remote administration (TCP 197.221.242.164:41259->31.51.59.156:443 on ppp0)
11:36:29, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [197.221.242.164:41213] CLOSED/SYN_SENT ppp0 NAPT)
11:36:28, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [197.221.242.164:41167] CLOSED/SYN_SENT ppp0 NAPT)
11:36:04, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [41.43.69.162:17408] ppp0 NAPT)
11:36:03, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [185.23.124.116:10443] ppp0 NAPT)
11:36:02, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [41.43.69.162:17440] CLOSED/SYN_SENT ppp0 NAPT)
11:35:56, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [185.23.124.116:10460] CLOSED/SYN_SENT ppp0 NAPT)
11:35:50, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 66.188.84.191:15618->31.51.59.156:64286 on ppp0)
11:35:46, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [31.51.40.178:14272] ppp0 NAPT)
11:35:38, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 24.65.107.216:28372->31.51.59.156:64281 on ppp0)
11:35:24, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [89.217.1.68:46730] ppp0 NAPT)
11:35:18, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [78.222.66.1:5497] ppp0 NAPT)
11:34:00, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [31.51.40.178:49497] TIME_WAIT/CLOSED ppp0 NAPT)
11:33:33, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 96.21.145.5:64938->31.51.59.156:64177 on ppp0)
11:33:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [78.222.66.1:51046] TIME_WAIT/CLOSED ppp0 NAPT)
11:33:27, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 96.21.145.5:64938->31.51.59.156:64177 on ppp0)
11:33:24, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [89.217.1.68:46730] ppp0 NAPT)
11:33:18, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [182.185.225.107:25180] ppp0 NAPT)
11:33:11, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 37.252.162.157:80->31.51.59.156:64144 on ppp0)
11:33:08, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 37.252.162.22:443->31.51.59.156:64145 on ppp0)
11:33:07, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.197.59:443->31.51.59.156:64143 on ppp0)
11:32:59, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [31.51.40.178:14272] ppp0 NAPT)
11:32:58, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [31.51.40.178:49497] CLOSED/SYN_SENT ppp0 NAPT)
11:32:31, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [78.222.66.1:5497] ppp0 NAPT)
11:32:30, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [78.222.66.1:51049] LAST_ACK/FIN_WAIT_2 ppp0 NAPT)
11:32:30, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [78.222.66.1:51049] CLOSED/SYN_SENT ppp0 NAPT)
11:32:28, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [78.222.66.1:51046] CLOSED/SYN_SENT ppp0 NAPT)
11:32:25, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [151.227.204.128:52515] TIME_WAIT/CLOSED ppp0 NAPT)
11:31:46, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 178.74.60.55:63409->31.51.59.156:64093 on ppp0)
11:31:34, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [77.101.113.161:57726] CLOSED/SYN_SENT ppp0 NAPT)
11:31:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [77.101.113.161:56942] FIN_WAIT_1/ESTABLISHED ppp0 NAPT)
11:31:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [77.101.113.161:56942] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:32, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [77.101.113.161:56942] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:24, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [151.227.204.128:52520] LAST_ACK/FIN_WAIT_2 ppp0 NAPT)
11:31:23, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [151.227.204.128:52520] CLOSED/SYN_SENT ppp0 NAPT)
11:31:22, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [151.227.204.128:52515] CLOSED/SYN_SENT ppp0 NAPT)
11:31:17, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [182.185.225.107:25180] ppp0 NAPT)
11:31:16, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:22003] FIN_WAIT_1/ESTABLISHED ppp0 NAPT)
11:31:15, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:22003] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:15, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:22003] SYN_SENT/SYN_RECV ppp0 NAPT)
11:31:15, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:22003] CLOSED/CLOSED ppp0 Route)
11:31:00, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [80.103.184.143:55081] ppp0 NAPT)
11:30:32, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:3542] SYN_RECV/SYN_SENT ppp0 NAPT)
11:30:26, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [75.186.86.205:40655] ppp0 NAPT)
11:30:13, 25 Jun. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.68:59814->195.135.250.57:3542 on ppp0)
11:30:11, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [76.23.249.251:4593] ppp0 NAPT)
11:30:11, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:3542] CLOSED/SYN_SENT ppp0 NAPT)
11:30:09, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP 192.168.1.68:59814 <-->31.51.59.156:59814 [195.135.250.57:22003] CLOSED/SYN_SENT ppp0 NAPT)
11:29:28, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 23.62.98.194:80->31.51.59.156:50312 on ppp0)
11:29:26, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.65:64033 <-->31.51.59.156:64033 [212.33.102.60:20535] ppp0 NAPT)
11:29:16, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [41.109.250.12:11212] ppp0 NAPT)
11:28:59, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [80.103.184.143:55081] ppp0 NAPT)
11:28:50, 25 Jun. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.194.246:443->31.51.59.156:64042 on ppp0)
11:28:33, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [157.55.130.142:40001] ppp0 NAPT)
11:28:25, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [75.186.86.205:40655] ppp0 NAPT)
11:28:10, 25 Jun. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [76.23.249.251:4593] ppp0 NAPT)
11:28:09, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [103.241.47.102:39693] ppp0 NAPT)
11:27:45, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [76.23.249.251:59834] ppp0 NAPT)
11:27:28, 25 Jun. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.1.68:59814 <-->31.51.59.156:59814 [82.39.129.210:56176] ppp0 NAPT)
END LOG
Download 0.10
Upload 0.24
DIAGNOSTIC TEST on Phone Number
 Download speedachieved during the test was - 0.1 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 12.92 Mbps
Upload speed achieved during the test was - 0.24Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
john46
Message 8 of 22
looks like it sorry
twedledee
Message 9 of 22
My posts keeps vanishing?!
LOG
END LOG
Download 0.10
Upload 0.24
twedledee
Message 10 of 22
2nd time vanishing, whats up BT!
LOG
END LOG
Download 0.10
Upload 0.24
Tags (1)
