Message 1 of 6
BTHomeHub 3 Orange BB light every morning
For the last week I have been having issues with my BB, the orange light is on every morning and I have to reboot the hub to get a connection again.  The previous owners left a homehub3 in the house so I have been able to swap my hub with another homehub3.   Both routers have the same issue. I've taken them both back to factory defaults and the problem still exists.  Everyday a fresh reboot.
When connected I get approx 5.5mbps down, and 448kbps up.
My stats, 2 hours after a reboot this morning  -->
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 01:54:24
Downstream: 5.656 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Fast
Noise margin (Down/Up): 6.0 dB / 26.0 dB
Line attenuation (Down/Up): 40.2 dB / 25.0 dB
Output power (Down/Up): 19.7 dBm / 12.1 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 375 / 0
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 678 / 0
Error Seconds (Local/Remote): 197 / 3
Are the HEC and Errors normal?
My master socket looks pretty old, brown in colour and looks to be about 20yrs+, I use the external ADSL filter, again I have 2 filters and have swapped them but it's makes no difference. Replaced the RJ11 lead from the filter to the router. Still the same, everyday I have to reboot.
Any other suggestions?
5 REPLIES 5
Message 2 of 6
Re: BTHomeHub 3 Orange BB light every morning
is it the broadband light that is orange or the wireless light?  how do you conenct to the router - wireless or ethernet?
Message 3 of 6
It's the middle broadband light, i've got wired and wireless connections. Wireless holds up as I can login to the homehub over it.
Message 4 of 6
if it's wirelless have you got the power saver activated as that stops wireless during the preset hours
Message 5 of 6
I can also confirm that the power saving feature isn't used, its disabled on both routers.
Message 6 of 6
after 6 hrs, still connected
ADSL Line Status
Connection time: 0 days, 06:12:24
Downstream: 5.688 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 5.5 dB / 26.0 dB
Line attenuation (Down/Up): 40.4 dB / 25.0 dB
Output power (Down/Up): 19.7 dBm / 11.9 dBm
FEC Events (Down/Up): 0 / 6
CRC Events (Down/Up): 2108 / 1
HEC Events (Down/Up): 8823 / 3
Error Seconds (Local/Remote): 913 / 7
