elmgrove69
Message 31 of 44
Re: BTHub 3 Kodak ESP Printer - wireless printing issues
Please help.
My kodak printer worked fine wirelessly on my old hub
but since infinity was installed
the laptop can not find the printer and i get blue flashing lights on the printer.
i am not technical,
so be gentle with me !!!!!!!
Christine
Message 32 of 44
have you entered the new security wireless code from your new hub into the printer ?
Message 33 of 44
Have you read all of this thread from the first page?
Also, your printer is listed on this page
Help with setting up routers, wireless repeaters, TVs and printers, VOIP Phones
Ipswichblade
Message 34 of 44
You will see from the posts that I had problems back in 2011 however i found a solution and then the problem stopped. Fast forward to Feb 2013 and the problem with the printer is back, I had Infinity fitted in December but no other changes. The solution is still the same switch form b/g to b/g/n apply then switch back and apply again. The worst thing however is that one of the laptops in the house now has the same problem, not just the printer. So my questions are why would this problem suddenly start again after iover a year and why is one of the laptops (not all) having the same issue
Any ideas?
N_Vic
Message 35 of 44
I have the same problem and use the same solution.
Had a Kodak Wireless C310 - set it up worked fine for months, then all of a sudden it stopped working, I tried disconneting it from the network and reconnecting, this would occasionally work but no longer. The only solution is I change the HomeHub settings from b/g/n to b/g then it works....for a while....then to fix again I change it back from b/g to b/g/n and the print queue downloads and its off again.
There is plainly some sort of comms issue between the two of them and presumably by making these changes the printer is re-establishing itself on the network some how?
But it is not a kodak problem as I have a Lexmark that exhibits alarmingly similar behaviour!
Is anyone able to explain what is happening and why this works? Can BT fix it?
I had lots of problems with a vodafone sure signal too, so I think there are connectivity problems that BT are not telling us about.
pobox999
Message 36 of 44
My Kodak C310 ESP printer just starting losing its wireless connection intermittently - oddly after having a replacment bthomehub (I'm using infinity) installed.
Its the second time its happened in a couple of weeks.
I cleared the problem by logging onto my bt home hub (ip addres=192.168.1.254 default I think) and selecting advanced settings - wireless and change the wireless channel number.
A minute or so after pressing apply the printer jumped back into life.
The workaround for this problem would seem to be to change the wireless channel. (Its odd that my laptop was working fine with the old channel when the printer had stopped working - some incompatibility beween the latest hub and the printer possibly?)
harpersimon
Newbie
Message 37 of 44
I have the same issue with the Kodak ESP printer, although its not limited to this printer just before anyone suggests the printer - its not.
BT - I know this is a public forum but the mods needs to forward this transcript to tech. dept for resolution.
There are enough people here with the issue now to warrant it. I've called and 'chatted' to BT and they deny the issue / want me to call a premium line for support/blame the printer etc but this is a protocol issue on the Home hub as proven many times above (otherwise the channelb/g/n fix wouldn't work)
I've tried everything, and I am technical - all happened after infinty came along so I am probably going to throw the BT hub in the bin and use ANOTher cable / VDSL modem to be frank and the BT hub is dross.
Message 38 of 44
which hub did you have before you changed to infinity
pobox999
Message 39 of 44
I had BT Home Hub 2 originally and the printer was fine. A BT Engineer replaced it with a BT Home Hub 3 which is when the printer problem started. Looks like there's a bug in the new BT home hub 3 wireless firmware (Note: all my other devices ipad, iphone, panasonic surround sound, qnap backup are ok - its a particular persistence connectivity problem between the hub and printer ?)
Message 40 of 44
have you read through Keith's link earlier in the thread there is nothing involving the hub firmware that would single out one printer manufacturer
