Message 11 of 44
Re: BTHub 3 Kodak ESP Printer - wireless printing issues
have you tried changing to just b/g?
have you tried setting a free static channel instead of letting the HH3 select the channel which means it can keep chnaging channel if other routers are switched on round about you.  the HH2 didn't have that facility
year0001
Message 12 of 44
year0001
Message 13 of 44
Sorry but this shows as solved but is it.....!!!!!!!!
Well it might be for some but not for me, not long switched to hh3 from hh2, now printer shows connected to hub; laptop connected to hub (both wireless). So obviously both "talking" to the hub, so WHY? OH WHY? can they not talk to each other for more than 5 minutes. so annoying.
Please can this be sorted out.
DavidB141
Newbie
Message 14 of 44
COME ON BT! This issue is dragging on. I have the same problem as all the others. My KODAK ESP 7250 printer is connected to the Hub. My PCs are connected to the Hub, but they do not 'see' the ESP printer. My HP6100 series printer works fine wirelessly. I have been hanging on for the last 2 months, waiting for this issue to be resolved.
linestony
Newbie
Message 15 of 44
hi, i had same problem with my kodak printer and did what you suggested and is now working fine! do you know if this will let my xbox connect wirelessly also? it used to work but stopped working a little while ago.
cheers
Ipswichblade
Message 16 of 44
Can this be put back to not solved as this is still an issue for me. I have had this problem daily since upgrading to Home Hub 3 last week and may have to go to usb with other computer users in the house sending me stuff to print. Surely some firmware or patch can be produced
Message 17 of 44
this was marked solved by the originator who obviously got a solution.  have you tried the solutions in this thread?
Ipswichblade
Message 18 of 44
Yes I have tried the b/g/n to b/g which fingers crossed as worked for the last 12 hours but the test will be if it is still working this time tomorrow, next week etc!!
I would have thought a more permanent solution so that the router can be put back to the BT recommended solution would be useful
Message 19 of 44
it does not appear to be a problem with the router just that your printer cannot handle the wireless 'n'  If it was a real problem which people had not solved then the thread would be pages long instead of just a few posts
Ipswichblade
Message 20 of 44
Still ok, as i said I just hope it stays stable and i will be very happy!!!
