Newbie
Message 1 of 4
BTHub3 Powered Off - Resume with half speed
Hello folks!
The long and short: BTHub3 was unplugged for 6.5 hours (apparently the vacuum cleaner was more important) and now I have half speed.
Prior to unplugging:
  • Down: 15Mb
  • Up: 1.5Mb up
Now:
  • Down: 8.4Mbit
  • Up: 217Kbit
Ouch. After seeing the new speeds, I power-cycled the Hub to see if it made a difference (surprise: it didn't).
Current connection detail:
  • VPI/VCI: 0/38
  • Type: PPPoA
  • Modulation: G.992.5 Annex A
  • Latency type: Interleaved
  • Noise margin (Down/Up): 6.1 dB / 5.9 dB
  • Line attenuation (Down/Up): 53.9 dB / 45.3 dB
  • Output power (Down/Up): 20.3 dBm / 12.1 dBm
  • FEC Events (Down/Up): 229737 / 433
  • CRC Events (Down/Up): 261 / 65
  • Loss of Framing (Local/Remote): 0 / 0
  • Loss of Signal (Local/Remote): 0 / 0
  • Loss of Power (Local/Remote): 0 / 0
  • HEC Events (Down/Up): 22366 / 74
  • Error Seconds (Local/Remote): 8 / 5
What is the best course of action for me, other than a little cry and a cup of tea?
Much appreciate any advice.
3 REPLIES 3
Message 2 of 4
Re: BTHub3 Powered Off - Resume with half speed
Have you tried connecting to the test socket with a new filter and see if that helps. With your current attenuation there is no way you could get the speeds you mention so suggest a line problem. You cannot get 1.5mb upstream on a residential adsl2 connection
Newbie
Message 3 of 4
Brilliant! I just swapped out the filter for a spare:
Line state: Connected
Connection time: 0 days, 00:00:43
Downstream: 15.84 Mbps
Upstream: 821.5 Kbps
Noise margin (Down/Up): 9.0 dB / 13.6 dB
Line attenuation (Down/Up): 15.1 dB / 6.6 dB
Output power (Down/Up): 20.0 dBm / 9.9 dBm
Thanks so much!
Message 4 of 4
Looks a lot better
