Hello @Montin99,
This problem did recur for me too. But I found a way to overcome it. Essentially my login ID used an '@btinternet.com' email address – which was causing the problem. So, first, I went straight to : https://www.bt.com and used the 'My BT' link at the top of the page. Amazingly, this got me into the MyBT account. Next, I clicked the 'My details' link within MyBT, and changed my BT ID Username to another of my email addresses, that was NOT ending '@btinternet.com' . Perhaps, for you, this could be an email address that ends: Google.com, or Live.com, or @icloud.com. I also changed my Password. This worked for me, but the key was to use the https://www.bt.com to get to the MyBT link in the first instance. Hope this will work for you too..?
Hello @Montin99,
The issue seemed to focus upon using my '@btinternet.com' email address as my BT ID - I needed to change my BT ID.
So, first, I went straight to : https://www.bt.com and used the 'My BT' link at the top of the page. Amazingly, this got me into the MyBT account. Next, I clicked the 'My details' link within MyBT, and changed my BT ID Username to another of my email addresses, that was NOT ending '@btinternet.com' . Perhaps, for you, this could be an email address that ends: Google.com, or Live.com, or @icloud.com. I also changed my Password. Your '@btinternet.com' email won't be lost, but changing your password will mean you need to reset it in all mail programmes. Hope this will work for you..?
Problem is I can't change any details other than forgot password. As I'm thrown straight into email rather than my BT information. Probably is the fact I have @btinternet.com in my ID, but simple can't get to the point where I could change it. Very frustrating.
Also worth noting that trying to go to BT from the email page takes me to a BT login page than simple loops on itself when I try to log in (and I've try different browsers). I get the feeling the issue is BT end of things. And trying to get in contact with BT is ironically rather difficult.
Hi @Montin99 welcome to the community and thanks for posting, I'm sorry to see you're having issues accessing MyBT. May I ask what web address are you using? Can you make sure it's www.bt.com/mybt
Neil
Hi @Montin99,
This does sound like something that we can help you with.
By any chance, do you have more than one BTID for the same BT account number?
Let me know as I believe I can fix this.
DanielS
Sorry for the delay in replying. I probably do have more than one BTID for my account though I generally only use BT for my broadband. Email I run through either hotmail, gmail or Sky, so I honestly don't remember what ID's I have setup with BT. And as I can't get logged in, I can not check. It still dumps me straight to mail.
Hence I very much need someone BT end to fix this (DanielS, I hope you can help)!
Hi @Montin99 thanks for posting back and I've sent you a Private Message with details on how to contact the Mod team and we'll be happy to help you with this.
cheers
John
Having the same issue tried chome and edge still the same BTID goes to webmail
Hi
Ive seen that yu have sorted this problem for someone previously. I am having the exact sme problem....HELP
