Hi, is there any way to disable this really annoying and totally pointless error message? Thanks for any help!
Graham
This will probably explain why you're getting that error...
https://support.youview.com/youview-box/error-messages/fix-for-yvm302/
Thanks for that, I know why I'm getting it, I'd like to disable it. I don't need a message that prevents me watching the program popping up every few minutes to tell me the signal is bad. The pixelation tells me that. Annoyingly the picture itself is perfectly watchable except for the message popping up which requires me to hit the back button constantly 😞
Is it possible to disable it?
Thanks,
Graham
I don't think so 😔
