Message 31 of 44
Re: My BT Package Overview - Your BT TV "Error retrieving your details"
I just checked again at 2100 on Sunday and I still have the same error message.
Recognised Expert
Message 32 of 44
Re: BTTV details cannot be viewed on My BT
I still have the errror for the TV package @DavidM, I'm not convinced that BT know what is causing this It's a serious concern, a customer should be able to see what they have subscibed to.
Moderator
Moderator
Message 33 of 44
Hi @Andy005 and @naples98 Thanks for checking and sorry it's not been fixed for you yet. They have identified the cause of the fault so we will chase them again on why it is still happening and update you when we hear back.
cheers
John
Message 34 of 44
Any update on this? I'm still getting the error.
Thanks.
Recognised Expert
Message 35 of 44
I'm getting this error too
Recognised Expert
Message 36 of 44
It's been fixed for me now, I can now see all of my package details.
Tthanks for your help @JohnC2 and @DavidM.
Message 37 of 44
It has been fixed for me as well. Thanks for the help.
Recognised Expert
Message 38 of 44
Yes working for me too, Thanks
Message 39 of 44
Mine is working too now.
Rich.
Moderator
Moderator
Message 40 of 44
Hi guys,
Thanks all for letting us know this is sorted. @tim11 can you check if this is sorted for you as well?
Cheers
David
