Message 1 of 6
BTWiFi from laptop
Can I access BTWiFi-x from a laptop?
I have tried to login using by BT account details but it does not work
5 REPLIES 5
Message 2 of 6
Re: BTWiFi from laptop
BTWifi-X is for Apple devices.
Message 3 of 6
Thanks, shame the BT website doesn't appear to mention that anywhere??
Message 4 of 6
Just tried from iPad and still will not connect?
Message 5 of 6
It is utter rubbish, it works if you are prepared to spend all your time holding your device at the window on the east side etc.
I tried to boost it with a router which used to work but no more.
I no longer consider it a benefit and when I renew next month I will probably go with Sky
Message 6 of 6
Ironic that I cannot even post here because it drops the connection
