jac_95
Guru
Guru
Message 1 of 1
BTWifi Cisco VPN for MacOSX
Hi all,
I noticed this a while back but though it was just me.
Then I noticed that another person was also having the same problem.
Link to OP's post here: http://community.bt.com/t5/BB-Out-About/BTWiFi-VPN/td-p/747400/highlight/true
Link to my reply: http://community.bt.com/t5/BB-Out-About/BTWiFi-VPN/m-p/795452/highlight/true#M9904
Basically when you connect to a BTWifi or BTWifi-with-Fon hotspot and log in, then start up the BTWifi Cisco VPN software you get an error message (51) and will not allow you to establish a VPN connection.
I'm running OSX 10.7.5 on a MacBook Pro.
All the other versions of the free cisco vpn software off the btwifi website work on other devices (ie Windows, iPhone versions work fine.)
Was wondering if anyone else had this problem or if there was any news on this problem.
Cheers
James
