Message 1 of 11
BTWifi-with-FON
Hi there,
How can I ensure I’m opted out of the BT WiFi network/BTwifi with FON? I’m pretty sure I went into “my BT” and opted out but when I check my router settings it still appears to be opted in?
Some assistance in turning it off / opting out would be appreciated.
10 REPLIES 10
Message 2 of 11
Re: BTWifi-with-FON
It can take up to 28 days before your hub shows btwifi as off. Just need to wait
Message 3 of 11
Re: BTWifi-with-FON
Hi,
Thanks for the reply, but I can confirm it’s been over 28 days since processed it as off in my account yet it’s still showing as on within the router. How can I escalate it to get it switched off as originally requested?
Cheers
Message 4 of 11
Re: BTWifi-with-FON
Hi @Lukecoleman8 I suggest you repeat the opt in/out again from my BT. Then switch off your hub for few hours or leave it overnight if you're not using broadband.
Message 5 of 11
Re: BTWifi-with-FON
Hey,
Appreciate the reply and suggestion but I’ve tried the opt in/out process already with no luck. Is there anyone I can escalate it to from within BT who can just ensure it’s disabled once and for all for me?
thanks
Message 6 of 11
Re: BTWifi-with-FON
Hi , can anyone help? Tried all the suggested steps yet it’s still “on” via the router settings.
Message 7 of 11
Re: BTWifi-with-FON
Hi @Lukecoleman8 which hub you are using now? Is there any particular reason that you want to opt out?
Message 8 of 11
Re: BTWifi-with-FON
Hi, I’m using the latest smart hub 2. I have no need for the facility and hence want it off. As I said opted out months ago, yet it’s still even after rebooting my router showing as “on” within settings.
Message 9 of 11
Re: BTWifi-with-FON
I have asked mods to help you opt out btwifi. They will post here
Message 10 of 11
Re: BTWifi-with-FON
Thanks, much appreciated
