Johnoo
Expert
Message 1 of 25
BTYahoo Mail Time Recorded
Just set up BTYahoo mail on a new computer running windows 8
Problem the time showing on e mails is 8 hours out, ie showing sent at 13:00 when actually sent at 21:00
Can't see why, computer time is set correctly
Any ideas?
24 REPLIES 24
vofsanity2
Recognised Expert
Message 2 of 25
Re: BTYahoo Mail Time Recorded
Any ideas?
I suggest you go into your email account information and check the Time Zone is set to UK.
Johnoo
Expert
Message 3 of 25
Tried to find "Time Zone" in Account information but can't see it there.
Could somebody please point me in right direction
vofsanity2
Recognised Expert
Message 4 of 25
BT Yahoo put this in a place where you are unlikely to find it.
Login to BT Yahoo
Click on My Account
Click on Edit Personal Information
You will be asked to sign in again
Click edit Yahoo Address/ Contact Information
At the bottom of the page you will find Time Zone Information (This defaults to US Pacific Time)
Use the drop down to change to  GMT UK, Spain
SAVE CHANGES !!!
SIMPLE !
Johnoo
Expert
Message 5 of 25
Found it & checked what is set.
The current setting is Time Zone:- GMT UK Spain & I am located in the UK.
BUT
Just sent a test e mail to myself & it is timed at 04:44 rather than 12:44
Ideas to solve please!
Message 6 of 25
where does windows 8 think it is?
Johnoo
Expert
Message 7 of 25
Well rom the Control panel is says it's in the Uk
Also the time bottom RHSsays it's 14:00 on the 08/08/13
So I think that is all correct, (Unless I'm Dr. Who)
vofsanity2
Recognised Expert
Message 8 of 25
BUT
I think we need to be a bit more systematic.
I assume you are using webmail.
What time is displayed for the email in the sent mail folder ?
When you receive the email what time is shown in the INbox.
If you display the header for the email  what time is displayed in the various hops.
If you are using an email client same sort of questions.
Johnoo
Expert
Message 9 of 25
Yes I am using web mail (BTYahoo)
I have done a new trial seding to myself couple of minutes ago, results:-
Sent Box copy time sent 6:53
Received Time Copy 6:53
Show Header data 6:53 on 8th August
Hope this helps you & me
vofsanity2
Recognised Expert
Message 10 of 25
What that shows is that the time is being set before the email leaves your machine. (i.e. it is not changed on route)
Let us find out what time the browser thinks it at.
If you create a new favourite and then right click on it and look at properties what time does it say it was created at ?
