sevenacregreen
Message 1 of 3
BTcloud down or having problems
Trying to log into btcloud website I get
                  Error
System error:  Please login after some-time
(Firefox on W10)
Windows BTcloud app just giving logon screen
not very helpful!    Android app failing to coinnect.
Is there anywheer I can find the status???
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: BTcloud down or having problems
@sevenacregreen That's not good, did you manage to get access to your cloud service resolved? Post back if you need any help getting this sorted.
sevenacregreen
Message 3 of 3
Connection restored after a while. The first indication was that the app running in W10 presented the login screen. Then as described in my post for about an hour then it all worked again.
