OLD_MAN
Message 41 of 43
Re: BTs Outrageous Data charges
"Trying to catch up here on what has been happening, I see on a post by OLD_MAN that he received a charge of £0.25p for "USAGE".
I may be wrong but I am sure that this charge is for MMS, which is NOT included in Data or SMS charges.
Looking at the on-line billing MMS is show as a seperate item and each and every MMS is chargeable."
Thanks for the comment Ray but I can assure you that this is definitely not the case (never used MMS).   To put my later post/theory to the test, have a go at adding or modifiying your mobile contract and you will have a charge for activities on your mobile at the point where BT acually takes time out to transacts that change.   As I said before... don't download Lord of the Rings until your new contract conditions are in place!
OLD MAN ( 3 x 20 + 10 and still no Valentine Card! Smiley Sad)
Anton
Message 42 of 43
asda charge 20P....
Anton
Message 43 of 43
It is easy to send a mms when you thouught you were sending an ordenary text. Also if you fowarded a contact  or a ring tone it would go by mms.
