alanslingsby
Message 1 of 11
BY Infinity and DECT
Just had Infinity installed. Works fine. BUT cannot make most outgoing calls from a four-handset BT Inspire 1500 DECT phone that was working perfectly before. CAN connect to talking clock (123) but not to regular lines. Message is "number not recognised". Incoming calls OK. BT engineer checked thoroughly and says all in order with lines etc. DECT hub is plugged into main socket, Infinity connected to an extension. This set-up was used for regular ADSL for upwards of five years and worked perfectly at all times. Engineer says problems DECT phones and Infinity. Any ideas???
10 REPLIES 10
Bullitt
Distinguished Expert
Message 2 of 11
Re: BY Infinity and DECT
infinity should not be on an extension
this installation is wrong
Deathtrap3000
Recognised Expert
Message 3 of 11
Data extension kit = extension
Bullitt
Message 4 of 11
oh you mean the home wiring solution hws?
Deathtrap3000
Recognised Expert
Message 5 of 11
I mean data extension, its covered under the hws. Infinity can be run on an extension. It doesnt need to be fitted at the master socket. It just needs to be a dedicated extension for the broadband.
Bullitt
Message 6 of 11
thats not necessarily what the poster meant
Deathtrap3000
Recognised Expert
Message 7 of 11
If hes using a plug in filter into one of the phone sockets, yes its been done wrong. If no plug in filters are being used, its ok.
Bullitt
Message 8 of 11
odd he can call the talking clock
could that be a cab problem?
nelami
Message 9 of 11
Hi I dont know if your problem has been fixed or not but I had the same strange fault. Was upgraded to Infinity on Wednesday. Didn't reallycheck the phone while engineer was here other than ringing 123 which was ok. Later wife said that all o/g calls were  not recognised when DECT phone was used but old loop dialling phone ok. After several call to India and  various tests and threats of being charged for a site visit I decided to check the wiring in the master socket. I knew that the extension sockets were correct. The pair were reversed ie 2 & 5 were wired the opposite way to the extensions. I reversed them and all is working. Don't know why the reversal should interfere with the dtmf signalling.
Hope this helps
plainview
Recognised Expert
Message 10 of 11
@nelami
'The pair were reversed ie 2 & 5 were wired the opposite way to the extensions.'
Don't suppose you remember if the engineer drove a Vauxhall Combo, Transit or a Vauxhall Vivaro do you?
