Just a quick question having read a recent thread here.
How do you determine whether a line has been banded or not ??
Solved! Go to Solution.
Did you read this, as it explains it better than anywhere else?
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
If your downstream noise margin is higher than 6dB, then you are in a banded profile.
Thanks for the info.
At present my noise margins are 6/6.4 and and have been that way for quite some time now.
Then its unlikely to improve any further.
What is the problem?
Not so much a problem but with a max data rate of 30+ I only ever sync at 27.4 giving me an actual download speed of around 24.
The sync rate of 27.4 never changes even by a small amount but the upload rate does seem to vary a little.
Hi @Black_Infinity and thanks for posting.
@Webby might be correct here so I'll be happy to take a look at this for you. Can you run the speed test including the further diagnostics and post the results?
Cheers
David
Thanks David, here is the info you requested
