Black_Infinity
Message 21 of 36
Re: Banded connection.
Thanks for the explanation.
I will monitor for a while to see what happens next as I am now connecting at less than the guaranteed minimum 😞
licquorice
Message 22 of 36
Are you connected to the master socket or an extension?
Black_Infinity
Message 23 of 36
Connected to the master socket
licquorice
Message 24 of 36
If you have any extension wiring, it might be worth leaving the hub connected to the test socket behind the removable faceplate to ensure your internal wiring isn't having an effect.
Black_Infinity
Message 25 of 36
OK.  Been there before but I'll give it a try.
Webby
Message 26 of 36
Re: Banded or Not ??
I suspect there's a fault given that the max attainable rate is also dropping.
Black_Infinity
Message 27 of 36
I will monitor for a few days and if necessary flag it up as a fault with Bt.
Bt have checked my line and say there are no problems but I've heard that before Smiley Frustrated
Black_Infinity
Message 28 of 36
New figures for today. Speed down even lower now and again , seems to be connected to a rise in noise margin !!
Now even further below the guaranteed minimum speed of 20
Webby
Message 29 of 36
You need an engineer visit.
Black_Infinity
Message 30 of 36
Thanks.  I thought thats where we might be heading Smiley Wink
