Bicceh
Message 1 of 7
Bandwidth Throttling on 'Discord' voice comms
Over the last 2-3 days there has been a very obvious change for me on Discord (a voice communcations programme) while on BT.
Anyone not using them as an ISP is fine, however i'm experiencing huge packet loss / latency issues where the programme is useless at times. This (as far as i can see) is down to BT thorottling the programme.
Discord works like a P2P facility as far as i know, so it may be something to do with that. But it's a perfectly legal programme / application / whatever so should work fine
6 REPLIES 6
Webby
Message 2 of 7
Re: Bandwidth Throttling on 'Discord' voice comms
BT don't throttle any longer.
DanielS
Moderator
Moderator
Message 3 of 7
Hi @Bicceh,
We wouldn't be throttling your speeds. Have you noticed any issues with any other services or is it solely with Discord's servers? Are your broadband speeds ok?
DanielS
Bicceh
Message 4 of 7
Absolutely everything is perfect except for Discord. On the three different server I've tried it can be OK for around 10 minutes, and then become a mess.
The only other people who I speak to who suffer from the same issue are people on BT also
Bicceh
Message 5 of 7
Just to show everything is fine bar discord:
My current speed:
My Current Line Stability:
Discord:
See that lovely up and down line? It's not meant to go up and down............
DrBerk
Message 6 of 7
I have exactly the same issue, as does a friend who has just moved to BT.
Additional observations are that often when I attempt to disconnect then reconnect to the voice servers, and it produces a No route error.
Most of the problems are resolved temporarily by rebooting the homehub, but obviously with multiple users, it's rather inconvenient
vulcan86
Message 7 of 7
I have this issue now; I moved to BT within the last month.
I really don't knnow what's causing it. Restarting the hub hasn't helped at all.
It appears at it's worst around 7pm-10pm in the evening on weekdays.
Has anyone got any suggestions on what I should do here?
