Message 1 of 5
Bedtime Settings on Whole Home WiFi App
This is probably a stupid question but need to double check how the times on the Bedtime settings work.
If I set an off time on Fri & Sat of 2430 and an on time of 1200 (midday) will this turn the internet off at 2430 on Saturday & Sunday morning or will it do it on Friday morning and not Sunday?  It's the switch over across the midnight boundary that's confusing for these settings.
Basically I want week nights set to go off at 2200 and come back on at 0800 the next morning.  For weekends (i.e. Friday night, Saturday and Sunday morning) I want the internet to go off at 2430 on Saturday & Sunday morning and back on at 1200 on Saturday afternoon and Sunday afternoon.  Would this require a custom schedule rather than the Bedtime schedule?
4 REPLIES 4
Message 2 of 5
Re: Bedtime Settings on Whole Home WiFi App
Hey, do you mean 23:30 as in 11.30pm or do you mean 00:30 as in 12.30am in the morning? You'd be putting 00:30 for Saturday morning otherwise it would kick in from 00:30 on Friday morning.
Message 3 of 5
Sorry yes I mean 0030 as in half past midnight and on again at midday.  That's what confused me as the bedtime settings are for Sun - Thurs and then separate settings for Fri & Sat.  So in this case I'd need to create a custom schedule rather than use the bedtime setting which doesn't allow me to distinguish between Fri & Sat?
Message 4 of 5
When you are setting up the bedtime schedule, you should be able to tap on the Sunday to remove it. You can then set up a custom schedule to include Fri, Sat and Sunday. To add or remove a day, just tap on that day, put your times in and save it.
Message 5 of 5
Excellent thanks for that.  Just what I needed.
