smashngrab
Newbie
Message 1 of 7
Beeping message alert on BT6500, can i stop it ?
Can anybody tell me how to stop the beeping om my Bt 6500 its very annoying, cheers.
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Beeping message alert on BT6500, can i stop it ?
Hi smashngrab,
Welcome and thanks for posting. You might find the answer here. Let us know if that helps.
Cheers
markleech
Newbie
Message 3 of 7
Yes you can - and here is how to do it.
1. On the handset select Menu, Answer Phone is displayed, press Select
2. Press CALLS until Settings is displayed, press Select.
3. Press to highlight Ans. & record and press Select.
4. Press to display Message alert and then press
or to select  On or Off and select Save.
Saved will be displayed and the annoying machine has now been de-beeped lol for good.
Jonesit
Newbie
Message 4 of 7
Brilliant! Thanks. It works the same on BT8500
jmesney
Message 5 of 7
Thanks very much. Also works for BT2500 (Usefully, the number of rings before auto-answer is also set using this menu option).
mimicath
Newbie
Message 6 of 7
Thank you so much - took me a while when I first came home to track down where the beeping was coming from! prolem now solved
tweed08
Newbie
Message 7 of 7
Thanks! It was useful to know that the beep when a message is left is called a "message alert".
On the BT Freestyle 650, you have to press and hold the "backwards skip" button (just below Answer On/Off) on the base. After a couple of seconds, it will announce that "message alerts" have been turned off.
