Markiejd
Message 1 of 6
Best Setup for wireless Speed
Hi,
Just womering what the views were to getting the best speed from a new infinity circuit. Wired in I get 75/15 but on wireless this drops to 30/15.
Is it best bet to replace the Home hub. I have tried N adapters and changing the wireless interface type to 40 MHz but no real increase ?
Has anyone seen/managed to get any better results
Also I have this below but I can't disable. Is this right ?
Thanks,
BT FON:
Active
5 REPLIES 5
Guru
Message 2 of 6
Re: Best Setup for wireless Speed
In order to disable BT FON you will have to opt out of it, you could possibly invest some money in a N draft router with better wireless range and speeds, however, this won't guarantee much more or better speeds over wireless.
I would've suggested homeplugs myself and odd your have seen no real increase.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
mitchgoeswild_199
Message 3 of 6
I am having the same problem on wireless speeds mine ranges from 10-35mb download but the upload is always 16+.
Wired Speedtest
http://www.speedtest.net/result/1970851010.png
Wireless Speedtest
http://www.speedtest.net/result/1970839405.png
Distinguished Expert
Message 4 of 6
WPA2 AES is faster than WPA2 TKIP
ianm42
Message 5 of 6
I get 52Mbs wireless speedtest on my Draytek 2750 to my laptop.
I assume must be connecting Wireless N.
smartie
Message 6 of 6
My best speed over wireless used to be 30-35mbps, upload around 16mbps, after changing the hh3 wireless settings to 40mhz & enabling the 40mhz function on the wireless n adaptor on my laptop (which was disabled by default!!) I have just had a speedtest result of 70 mbps down!!
I also had a massive ping decrease which was previously jumping around all over the place and usually 100+ms, after making the changes above and running the ping command I'm getting a much more stable ping of around 20ms.
http://www.speedtest.net/result/1971328969.png
I know have a wireless connection which is 98% as good as my wired connection, which gets me 75 down.
