Message 11 of 13
Re: Best router for Infinity 2 ?
Newbie
Message 12 of 13
thank you, will see how i get on with this
Message 13 of 13
I'm thinking of getting the Asus too.
The problem I'm trying to solve: port forwarding on the infinity router keeps breaking. I connect to my Emby server from outside the Wan, it will work for a week then it will stop. Only solution is to remove port forwarding, restart a few boxes, then set it up again.
What I don't need:
-wi-fi functionality as I use a NightHawk hotspot in the middle of the house for that.
- switch functionality. One LAN port is all I need
What I need:
- solid port forwarding capability
- solid firewall
- solid DSL.functionality, I have BT fiber to the house with 76MB download speeds
Would you recommend the Asus or other products for my specific requirements?
Thanks in advance
Ivan
