Message 1 of 3
Best way to extend cables to MT992 Modem or move BT Master socket
I currently have a BT MT992 modem connected to a Ubiquity Gateway, all within about 5 metres of the BT Socket and each other.  I would like to move the MT992 modem and gateway, is it best to extend the cable from the MT992 modem to the Master Socket or leave the MT992 modem adjacent to the master socket and extend the network cable from the MT992 to the Gateway, or doesn't it really matter which is moved ? Many thanks in advance for any advice.
2 REPLIES 2
Message 2 of 3
Re: Best way to extend cables to MT992 Modem or move BT Master socket
If it doesn't matter which you move, leave the modem where it is. It is always preferable to extend Ethernet rather than DSL.
Message 3 of 3
Many thanks for the advice, much appreciated !
