imjolly
Message 21 of 61
Re: Best way to get accurate information about Fibre availability?
Unfortunately yes and openreach will not move your line to a different cabinet just to improve your broadband. That explains the poor speed
jroden17
Message 22 of 61
yeah but why would my friend who is literally next door to Cab 7 be served from elsewhere, i dont even know where cab 5 is located...
The poor speed isnt caused by this ive had 1.9 or better for years, just last few weeks ive had a problem
jroden17
Message 23 of 61
There is poor speed and there is 0.12mbps, that is ridiculous, nowhere close to what I pay for
imjolly
Message 24 of 61
Your adsl connection problem is due to noise on your line causing an unstable connection resulting in high noise margin and low speed. I have asked mods to see if they can help
your fibre estimate has nothing to do with your poor adsl connection just the distance you are from cab5. Openreach will not move you to cab 7 just because it is closer to you and would improve your fibre connection speed
Webby
Message 25 of 61
Entirely possible.
jroden17
Message 26 of 61
Im not bothered about it just found it strange that my friend sits on cab 7 but is served by diff cab and thought that was an error in bt's information.
imjolly
Message 27 of 61
Possibly when you and your friends homes had phone lines installed cab 7 was not there and has been added subsequently the
jroden17
Message 28 of 61
Any update, its impossible to get news off bt about fibre availability
Webby
Message 29 of 61
No one here has any information about fibre availability.
Webby
Message 30 of 61
Have you contacted superfast cymru?
