Webby
Message 51 of 61
Re: Best way to get accurate information about Fibre availability?
Just to add, Openreach have continues recruiting more and more engineers to get the roll out progressed quicker.
It's THE fastest roll out of it's kind in the world.
James-C
BT Expert
Message 52 of 61
@jroden17
Which email address have you been trying to contact SFC with? was it the broadband@wales.gsi.gov.uk one?
I believe the info@superfast-cymru.com email is still being used, which was the original account they emailed responses from. I've recently been getting responses using this one so you could give that a try. There is a 5 day working aimed response time however they are usually good at replying back.
jroden17
Message 53 of 61
Yeah I had actually emailed the new one, will give the old one a try thanks for that!
jroden17
Message 54 of 61
So i've just got home and can for the first time ever get a 4G data connection of 18 meg usually only get 3g, is that any correlation that my local cab could now be more or less fibre ready?
Keith_Beddoe
Message 55 of 61
None at all.
jroden17
Message 56 of 61
Thankyou for shooting me down
jroden17
Message 57 of 61
Well SuperfastCymru finally got back to me but seems that there email response is just the generic 4months that the fibre checker website tells us, there twitter responses were a lot more detailed and up to date.
I had noticed that there was a big hole dug up right next to the cabinet on Saturday and also traffic lights and traffic cones, but the hole seems to have been filled and the roadworks are gone now so I guess that meant some work had been done.
jroden17
Message 58 of 61
So my cab is enabled and I ordered fibre, but I have to wait 14 days for activation and equipment... does that seem reasonable?
gg30340
Message 59 of 61
jroden17
Message 60 of 61
thankyou. I was reading other posts and seemed they had theres ordered and activated within days.
