Message 1 of 2
Big drop in sync speed
Hi,
I´m on on Infinity 2 Have had a pretty stablish connection of around 54-57 Mbps for some time, after high 60s in the golden days of little or no crosstalk.
However now I´m seeing 44-45 Mbps.  following the ducts along the road distance to cab is 350M.
Below is my wholesale checker and below that is my helpdesk output.
Yes, the SSID says hub3 I just used that rather than try and get everyone to change theirs.
Suggestions on what has likely happened will be gratefully receieved.
1 REPLY 1
Message 2 of 2
Re: Big drop in sync speed
Bump
