Hi,
Same here. I started out on Infinity 1 at 50MBPS download and line rate. Now it has fallen over the last month or so to a download rate of 37MBPS at a line rate of 44Mbps. Does switching off the router at night affect the rates and if so, why? I understand that BT can distinguish between a power down and a line break. Has anybody resolved this problem type? I am getting that old profile band feeling again that I got when I was on ADSL2!
the router is designed to run 24/7 and often the firmware updates are overnight so turning off router every night may stop any update - it also saves tiny amount of power and money
Yes you need hub connected
the constant daily turning off your hub is certainly not helping your connection speed. Do you turn it off overnight or do you only turn it on when you go to use it and then turn off so could be on/off more than once a day?
